Questions about Psu's
27 Nov 2008
Dublin,Ireland
At present i have this rig,
i7 920 c0 @ 4ghz
Evga x58 sli le
Ocz gold 6gigs 1333mhz @1520mhz
Ati 5770
8 x 12cm fans (low rpm apaches)
1 hard drive
1 optical drive
Corsair H-50
Antec P182
Be quiet 650w
I will be upgrading a few bits soon and have decided to use the spare bits to make a 2nd rig for my kids as i have an Asus P6t spare.
I will be adding a 5850,1600mhz ram,i7 930 and after i do some more research a decent WC loop.
I have to get a psu either way as i'm not brave enough to use the kids present psu with the nice i7 parts because its a hiper 580w of the explosive kind ;)
I wont be skimping on the brand though just not wanting to overkill on wattage.
Anyways down to the psu questions.
Would i get away using my psu if i added an ati 5850 and a WC loop with a decent pump? (i think it maybe borderline but this is why i'm posting)
Are Corsairs as quiet as Be Quiet psu's? (i cant hear mine at all)
Are there any other brands worth considering that are extremley quiet?
I was looking at seasonic as i believe the san ace fans are meant to be very quiet,is this true?
Thanks in advance for any suggestiong you have.
