- 21 Jun 2005
Hi guys
im well chuffed with my new games pc overclock. i bought a antec 900 case, abit ip35pro (flashed latest bios) with Q6600, crucial 8500c5 ram and thermalright ultra 120 extreme with 12cm fan strapped on. just want to check things are ok
i managed to get the pc stable at 3.4ghz (378*9) - superpi 1M is 14.86secs
to achieve this i had to set the vcore in the bios to 1.525v but in windows iguru application it only says 1.425 which seems about right voltage for that speed overclock? under nheavy load that goes down to 1.41v
i set MCH up 2 steps to 1.33v
ICHIO 1.55v
CPU VTT 1.27v
DDR2 to 2.2v and its running at 567mhz at 2:3 (1134)
strange things -
when i load cpu-z 1.41 to main screen seems to get confused with the multiplier which flicks from 6 to 9 and back
- but its defo 9
coretemp just bluescreens the machine so cant load that
the only application i can get to see the temps is speedfan which shows the cores under load to be 55c-58c - is this ok?
since getting this at these settings the pc hasnt crashed once and ive run 4 primes to stress for 3 hours and its fine
played COD4 for hour and fine
Cheers
Chris
ICHIO 1.55v
CPU VTT 1.27v
strange things -
- but its defo 9coretemp just bluescreens the machine so cant load that
Cheers
Chris
