- 12 Aug 2013
I know there is always a lot of threads for help but I'm very much in the early planning stages so hoping it's ok me asking these questions. I am looking to sell my Xbox Series X and possibly razer blade 15 (hopefully raise £800-900) to put towards a new gaming pc so I'm trying to work out how much extra is realistic to save without going overboard. Have some initial questions:
- I am hoping to be able to play 4k games on max settings for a good while before upgrading (few years). That being said, initially, I'd like to try to get an ultrawide monitor for games like Total War etc so, even though I can hopefully get a computer build capable of 4k, I may initially try 1440p ultrawide at min 120hz (4k at 120hz will of course be extremely expensive).
Is £2k max budget realistic including an ultrawide monitor? (4k monitor would be ok at a decent size but may end up waiting until 4k high refresh monitors are more common). - Obviously graphics cards are a big issue at the moment but what should I aim to get within that kind of budget? Would a 3070 be unrealistic in the budget, would it be needed or would it be overkill? Would a 3060 be a good option?
- If I wanted to try VR later down the line, would I need to take that into account with any selections I make?
- I know no one will know the answer to this right now should I assume a OC full build is the best way to go or are people starting to see prices start to fall again? Stupid question but are the full builds upgradable in future as with any build?
- Are there any components I should look to future proof (e.g. I'm guessing it's more difficult to upgrade a motherboard so should I look for one that would last through future upgrades or am I overthinking things?)?
- Assuming £2k seems a reasonable budget, what would a suitable split between tower and monitor be? (e.g. £1.3k for the tower and £700 for the monitor)?
- Intel or AMD?
- Obviously if I can get away with a smaller budget then even better and means I don't have to wait as long!
