Over the weekend I decided to have a dabble in connecting my PC to the TV with view to building a dedicated HTPC. The TV I have is a fairly basic model (it came with the flat lol) and is a 42" Hitachi Plasma HD Ready (i.e. 1080i not 1080p). It has a HDMI connection and a D-Sub PC connection. All the files were ripped from DVD to my PC using DVDshrink and are being played back as .vob using VideoLAN.
Firstly I used my laptop to connect to the TV using VGA to VGA D sub cable. According to the manual the max res on the PC input is 1280 x 1024. However I used 1280 x 768 (I think) and the picture was ok. A little washed out compared to a DVD player connected via component but ok.
I then tried my desktop PC (x1950pro) using the DVI to VGA convertor and then connecting into the VGA Dsub on the TV. The picture was a tad bit better but still not as vibrant as the DVD player via component. The DVD player has like a gloss finish to it whereas the PC is a bit like matt/silk if that makes sense.
My questions are: -
1. Is the max res of the screen in PC mode good enough to get a good picture from a HTPC? The actual icon text looked a bit fuzzy
2. Would I get a better picture getting a DVI to HDMI convertor and going into the TV via the HDMI socket? (I appreciate that the actual TV could be better using HDMI rather than VGA Dsub or Visa versa)
Thanks for the help
My questions are: -
Thanks for the help
