- 2 Dec 2006
Hello there, as you can see in my signature i am going to be buying a G8 and currently am looking at the BFG GeForce 8800 GTX OC2 768MB GDDR3 HDTV/Dual DVI (PCI-Express).
However, i was wondering do you think it would be better if i went for a cheaper card in the series and over clocked it to get the same result?
If so, which card (including make) do you think is better for over clocking?
What would happen to the warranty if i did over clock?
Also, how hard is it to overclock a G8?
Thankyou for your time
