After reading a few threads on here in regards to Sheds, I've ordered myself a 6x4 basic shed from Tiger Shed.
I now need to construct the concrete base before it arrives, but just want to check a few things here.
- I've excavated to 20cm with the intention of putting in 10cm of hardcode and 10cm of concrete, assume this is sufficient?
- What's the difference between Hardcore and Ballast, what would you recommend for the base and the concrete mix?
- Any issues with using sharp sand instead of builders sand? Reason being that I have some re-pointing to do which I need sharp sand for
- I'm intending to store my bike in the shed. In order to secure it I thought about putting an eye bolt in the concrete whilst it dries and cutting a hole in the shed base to tie the bike to. Any reasons why this may not work?
- I've I should make the shuttering circa 5cm longer and wider than it needs to be for the base, any reason why?
