Quick 3 slot GPU question check
9 Mar 2007
This is the first time I'll ever really be buying a powerful GPU, since I've been out of the building game for so long, so I just want to do a quick check...
The layout of this MSI boards looks such that it would take 2x 3 slot GPUs with no problem, as long as I don't plan on using any other cards. Is that correct?
http://www.msi.com/product/mb/P67A-GD53.html#/?div=Detail
Also, does anyone see any glaring problems with this board for an i5 2500K setup? It seems to do everything I want at a real budget price, with the opportunity to SLI in future if required (I checked PCI-E speed is 2x8). I doubt I'd OC the 2500K straight away, but would in future if I needed a performance bump.
Thanks.
