Quick 4890 Temp Question!
11 Dec 2003
Sol
Hey guys, just a quick Temperature related quaestion for my new 4890 I got today (First one was DOA and RMA'd by OcUK) currently seems to be idle/system running at ~42c GPU Temp, 42.5 (GISPIO), 49.5 (MEMIO), 42/5 (Shadercore)
I know the big "concern" really is gaming/stress temps, but just wanted to make sure this looked ok, worry a bit after the first one being DOA (XFX 1024MB 4890) :)
Cheers!
Absolutely fine.
with enough ventilation you shouldn't see temps over 70C, my o/ced 4890 doesn't hit more than 72 whilst running furmark in an Antec 902.
I'll try some gaming later then and pull GPU-Z onto the other screen, cheers guys.
Also what version of drivers would you recommend? (Running W7 Home Prem 64 bit)
Cheers :)
