Quick 5850 question
5 Jan 2007
Hey all,
My bro has a 5850 and I personally have a 470 so am a bit new with regard to ATI and the 5850.
We wanted to OC the Video card so I installed MSI Afterburner but have notcied that the highest selectable frequency is 775MHz.
How can I overcome this, do I need to flash the BIOS, any info?
Cheers :D
Edit: Its an HIS if that helps.
You need to enable unofficial overclocking in the afterburner config file and add some disclaimer text to it as well. Can't remember the exact text as I don't have access to my machine at the moment. Seach these forums and you'll find it.
If I remember tonight I'll post it.
What needs editing in the afterburner.cfg file.
[ATIADLHAL]
UnofficialOverclockingEULA =I confirm that I am aware of unofficial overclocking limitations and fully understand that MSI will not provide me any support on it
UnofficialOverclockingMode = 1
Should allow you past 775 if the BIOS allows it. My MSI was stuck at 775 before I changed this.
