Hi,
Just got Acronis 11 and using it properly for the first time.
I've set an incremental backup to go every week, Wednesday at 04:30.
Just wondered if the incremental will delete deleted files as well as copy new files/update existing files?
I know that some incremental backups don't delete deleted files so the backup gets huge over time, is this the case with Acronis?
EDIT
Also, which processes do I actually need for Acronis? (I want incrementals to run & I want to be able to browse existing backups)
Default on startup is: TrueImageMonitor, TimounterMonitor, schedhlp
Thanks,
Craig.
EDIT
Thanks,
Craig.
