I currently have a PC that I picked up 2nd hand from a friend. I have listed the spec below. Until recently I never thought about gaming on it as I have an XB1 & PS4. However I have played quite a lot of titanfall and a found that you could play for 2 days free on origin. So I downloaded it and installed the drivers for my xb1 controller and played through for a few hrs. Initially I turned all the settings up but while the graphics were great the frame rate was unplayable. However after getting a bit more realistic with the settings I was able to get a stable playable frame rate and I was surprised that even with my old card the graphics are still better than my xb1.
So now I am looking at possibly upgrading my graphics card and doing some more PC gaming in future. I dont have wads of cash to spend just now so I was thinking of changing my card from the current GTX 560 to either a GTX 750 TI or an R9 270 as that's about as much as I can afford just now. What i'm wondering is will this change make that much of a difference? Is it even worth doing or should I wait until i can afford a more substantial upgrade in the summer. Any thoughts would be welcome....
Current set up:
- Case: Antec 300 Gaming Case
- Power Supply: OCZ ZS 550w PSU (Bronze 80)
- CPU: Intel Core i5 2500K 3.30GHz @ 4.40GHz Sandybridge CPU
- Motherboard: Intel Z68 (Socket 1155) DDR3 Motherboard ** B3 REVISION
- Cooler: Corsair H60
- RAM: 8GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: Western Digital Caviar Blue 500GB SATA 6GB/s
- Graphics Card: Nvidia GTX 560 1024MB GDDR5
- Sound: Realtek 7.1 Channel Sound (On-Board)
Current set up:
