Quick airflow question on a Antec 300
5 Apr 2008
At the mo i have a noctua cpu cooler (see below) with both noctuas on the hsf with a push pull setup. Also with a fan at the back pulling the hot air out.
If i were to get 2 quiet 120mm fans fir the front would i want it pusing air into the case or pulling it out.
Load cpu temps on my 920 at 3.720ghz is 65 65 63 63 on p95
You'd have them facing inwards to draw air in, iif you don't have any at the moment it should make a big difference to temps
