Quick battery related question - help please ':O)
17 Feb 2004
london town
Hello all
just in the process of fitting a battery cut-off on my classic car.....called a dis-car-nect, allows you turn off the supply under the bonnet. It states that you should fit to the negative supply but there ain't enough room to do so, I've looked at turning the battery round to allow me to do so but I'll have to source longer leads ':O(
Quick question.....can I fit it to the + instead or will this have any repercussions i.e. drain the battery or should it do the same job?
Ta in advance
