Happy new year everyone....
Haven't got a clue regarding anything electrical really so just want some quick advice on how to extend the length of a rear exhaust fan, as described in the pic of my Antec case below...
Basically, I've overclocked my Q8400 cpu to 3.2Ghz (from the standard 2.6) and it's been stable for the last 3 weeks or so since...
However, I have the rear exhaust set to it's slowest (almost) silent speed for general usage, where it idles at around 36-38C! When I'm encoding video overnight though, it goes right up to about 65-66C - a bit too close to the chips max of 72C for my liking!
If I crank up the speed (and noise) via the controller/resistor at the back though, it brings the temps down to around the 60C mark at full load - BUT it means I have to get down on my (dodgy) knees and reach around the back for the little switch that controls it. I then go off to bed and let it do it's thing, quite happy with that temp.
In the morning though, I like to get it back to it's usual quiet self and have to get on my hands and knees again to set it back to it's 'normal' setting, not an ideal scenario!
Can I just get ANY similar thickness 2-core wire and cut the existing short cable and splice in the required 18 inches or so by just twisting together the ends and covering them up with insulation tape, to get the switch to where I want it at the top/front of the case, or does it have to be a certain ampage/rating type of thing?
Thx for any advice
Thx for any advice
