Quick bit of excel help!
1 Jul 2007
Various
Hi!
I could do with a quick bit of help in Excel, with something that I hope will be pretty simple.
I have two lists (lets call them A and B) of contacts. List A is a full list of contacts, while List B is a list of certain contacts which have been copied across from List A. All contacts on List B are on List A.
What I need to do is to delete all the contacts which are on List B from List A. Ideally I don't want to manually go through them all, as there are a good few hundred of them! Can anyone help? Thanks in advance :D
You could probably do a V Lookup to find them all, and then be able to delete them... google V Lookup, I'm terrible at it :)
Not sure VLOOKUP would work for what you want as it will just select Row B where Row A = your criteria.
Seems like you could do with some VB code to say if A1 Exists Within BX:BX then delete, then move to the next cell and repeat... unfortunately my VB abilities do not exist... lol
www.mrexcel.com is awesome for support though mate.
That wouldn't actualy do a delete though would it? Just count/sum the number that exist in both?
Yeah you're right I should have mentioned that :p, but then again I don't think there's a way excel can delete data short of a VBA macro?
I would just put the formula in Column C, and filter it afterwards to delete the data.
Try this in a macro:
Code:
    On Error Resume Next
    For i = 9 To 13
    cell = "G" + CStr(i)
    Name = Range(cell).Text
    Range("F9:F13").Find(Name).Delete
    Next
I'm removing all items in G9:G13 from the range F9:F13, so modify to suit your needs.
btw, this is a 2 minute hack, please no grief about what I've done wrong/what can be done better!
