quick bit of help (VGA CABLE)
25 Nov 2004
Just recieved my Hannspree 32" and i want to connect it up to my PC via VGA.
what cable do i need just VGA to VGA? or can i use the official 360 VGA cable and will that connect my 360 to TV aswell as PC to TV?
the hannspree should come with a vga-vga cable that you can connect to your PC's graphics card, check the cardboard box that contained the manuals and remote.
the 360 vga cable wont connect your PC to your TV as it has the xbox interface connector on one end.
