Quick bit of help with some SQL
29 Oct 2004
I have some MS-SQL I'm working on at the moment where I need to work out the % of successful appointments for reps based on a field in the Appointment table. Current SQL is:
Code:
SELECT repID, COUNT(*) AS success FROM Appointment WHERE (booked = 1) GROUP BY repID
Code:
SELECT repID, COUNT(*) AS fail FROM Appointment WHERE (booked = 0) GROUP BY repID
Now, both of these statements do exactly what I want, the problem is I want to do them both in the same statement so I can produce a ratio for each rep so I can go on and produce some charts/graphs
Desired output would be
repID = 1, conversion = 0.67 (2 success, 1 fail)
repID = 2, conversion = 0.50 (1 success, 1 fail)
and so on
Cheers for any help
Not sure if you can do it with SQL Server but with DB2 you can put those two queries within the FROM clause to give you something like:
Code:
select a.repid, a.fail, b.success
from (fail query) a, (success query) b
where a.repid=b.repid
I managed to sort the original problem with case statements but I'll certainly keep in mind your suggestion for any future issues.
