Quick Bitlocker Question
Bry
Bry
24 Jul 2005
A friend of mien has a vista 64bit laptop ultimate with the hdd encrypted via bit-locker.
He wants me to upgrade it to Windows 7 Ultimate. I dislike doing upgrades and want to do a format and fresh install.
My question is do I need to decrypt the drive via bit-locker in order to do a clean installation of windows 7? Or because it is software encryption I will just be able to boot from a windows 7 CD and do a full fresh install as normal?
P.s. reason for posting this here is that I think a lot more enterprises will of used bit-locker before as it is not a home feature.
fairly sure there isn't an upgrade option to 7, so you're only option would be a fresh install anyway. grab whatever data you need off the drive, and then just install over the top formatting the drive along the way.
You can upgrade to Windows 7 from Vista, but Vista has to have SP1 installed, you can't upgrade between 64 and 32 bit (and vice versa) and you can only upgrade to an equivalent or higher version of windows 7. (so you can NOT upgrade from Vista Ultimate to Windows 7 Professional, but you CAN upgrade from Windows Vista Home Premium to Windows 7 Ultimate)
http://technet.microsoft.com/en-us/library/ee424325(WS.10).aspx
