I have an old Nightjaw fanless silverstone psu, I have a 8 hole socket '12v ATX' to the side of the CPU on a Gigabyte A88x motherboard, matx (I know this powers the CPU).
I am not overclocking. Now I have a 4 pin cable and a 6 pin cable on my PSU with a few extra cables for cd-rom, HDD etc
The 6 pin is the kind of one you plug into the gfx card
Do I use the 4 pin? on the bottom 4 sockets?
Or do I need a newer PSU?
All advice appreciated, thanks pod
