I'll be gettin this spec soon I think, just wanted a quick check before I do buy it,
Will the GFX card fit the motherboard and case fine as it says its huge?
Is that the best gfx card to buy for that money, because all the GT cards are out of stock or on Pre-order.
All suggestions appreciated
