Quick car audio question
15 Jan 2005
UK
Hi,
Thinking about doing an amp/speaker/sub upgrade on my sisters recently purchased Mini. Do 4 channel amps generally allow you to change the gain on both channels independently?
For example, high gain on the component speakers stereo channel and low/medium gain on the subwoofers mono channel?
Actually I've just thought, can you even have 2x stereo and 1x mono? Do they all have to be the same? i.e. 4x stereo or 2x mono?
4 channel
2 channels front speakers HPF
3rd channel (3/4 channels) bridged LPF
That said its better to run a front speaker amp and a seperate mono dedicated amp.
An under seat would be rubbish as you say but the airbag light cabling is under there too and does cause problems later on in life as it wears without a sub under it. Just a heads u p.
Just remember that the "gain" pot on the amp is not a volume control. If the headunit outputs 2V don't set the gain to a voltage any lower than 2V. If you set it at say 1V it will clip the signal when the headunit is turned up. Minimum gain will be something like 4V and max is usually 0.1V.
Aye, I was just thinking that the fronts and backs might be wildly different but I think the fronts and sub will both be around 100W RMS anyways.
Another quick one :D How does splitting an RCA cable in to two work? Will I have 2 lefts on one side of the splitter and 2 rights on the other side?
RCA cables are a stereo cable. If your replacing the head unit you should have a front, rear and sub pre out so no need to split it.
I have no idea about the back of the head unit yet but I'm assuming it only has 1 line out, so I will need a splitter of some sort for the 2 amps? :confused: It's a cheap looking Sendai one that probably won't get replaced and if it does it won't be anything decent.
Ok, I'm going for a 2ch and a mono now. If I can find one with a passthrough that would be a bonus! Serious ebay trawling is required :D
