Quick case fan question
Caporegime
17 Jul 2010
I've managed to get everything from my old NZXT Lexa Blackline into my new Coolermaster CM690II but I have a question.
I've always used Molex connectors for case fans but for ease of cabling I've connected the case fans to the Sys Fan headers in the motherboard. Will I need to enable anything in the BIOS on first boot? They're connected to Sys Fan headers 1, 3 and 4. board is in the sig. Will they 'just work'?
Thank you kindly.
Thank you kindly.
They should just work. The only reason you should need to go into the BIOS is to adjust the fan speeds, and the monitoring. For instance, my motherboard stopped at boot because my CPU fan was running slowly. It's a 140mm fan that doesn't need high revolutions, so I had to go into the BIOS and lower the warning limit so it would let me boot with a slow fan.
