Quick case / PSU question
22 Sep 2005
Hello all
Just building a cheap system for a friend with the following spec.
AMD A64 3200 Am2
Abit KN9 NF4 Am2
OCZ 1gb value ddr2
NEC DVD-RW
WD 160GB SATA2
XFX7300 PCI-e
Akasa Zen case
with a FSP Sparkle 400 PSU to power things up, Would this power supply be ok and reliable for general use??.
Many thanks Paul. :p
Yer that should be fine, if I were you I would get a 775 kit though for better upgradability. As intel is not swapping sockets now until mid 2008.
Yer power wise 400w will be fine.
have no idea about that particular unit and its connectors/noise ratings without searching though.
I take it you have read reviews and the like?
