Quick Cee-Vee help please...
11 Jan 2008
Nowhere
Sorry but I have a couple of quick questions that I'm struggling to answer;
uno) Say I complete one year at university (of a 3 year course) and then drop out.
Do you think I should somehow mention this?
duo) Grades. Say I've had one job in my entire life, even padding it out this CV is gonna be pretty short.
So should I be listing all of my A Level Grades and all of my GCSE grades? Or does it not need to be that exotic?
threeo) I've seen some CV's on the interwebs with a career objective at the start. A single line defining what they are hoping to achieve.
Is this a good move or is only a very job specific requirement?
Cheers!
Merci di m'avoir si genereusement fait profiter ton temps!
What job are you going for? I hope it's nothing language based...
1. I'd say no...
2. it depends what they are. i.e. GCSE's it might be better to say 5 grade A-C, if you got 5 C's and a load of fails.
3. I would have thought job specific...
Best thing to do really is lay something out on a sheet and come back for advice. Then we can recommend what needs padding out and what doesn't. 1 page of A4 is enough, especially if you don't have much experience. Have you done any work experience?
