Quick Cheap Case & Cooler Question
14 Sep 2007
Hello all - hopefully a quick question
Will this case https://www.overclockers.co.uk/bitfenix-nova-midi-tower-case-black-ca-222-bx.html
Fit this Cooler https://www.overclockers.co.uk/tita...754-939-940-am2-lga775-lga1366-hs-008-ti.html
Case says up to 160mm cooler says 156mm so on paper it would but I'm just interested to know where the case manufacturers take the measurements for the height of the cooler as I've got the cooler in an old build (transferring cases) and from the mobo itself to the top of the cooler is 160mm-162mm
Anyone with the case who might know if the dims are generous or not would be appreciated.
Well based on the product info, yes. However just barely. Case advises CPU cooler up to 160mm and the Fenrir is 156mm
