Quick check before order
Caporegime
13 May 2003
Warwickshire
Just about to order the following as an all-round cheapish upgrade to my very aged Barton 2500 setup. Any last-minute changes you'd recommend?
Gigabyte GA 965P-DS4 iP965, S775, PCI-E (x16), DDR2 533/667/800, SATA II, SATA RAID, ATX £92.95 £109.22
250 Gb Seagate ST3250620AS Barracuda 7200.10, SATA300, 7200 rpm, 16MB Cache, 8.5 ms, NCQ £46.80 £109.98
Intel Core 2 Duo E6300 OEM, Socket 775, 1.86 GHz, 1066MHz FSB, Allendale Core, 2MB Cache, OEM £96.99 £113.96
1Gb CorsairXMS2, DDR2 PC6400 (800), 240 Pins, Non-ECC Unbuffered, CAS 5-5-5-12 £80.48 £94.56
256MB Sapphire Radeon X1950XT, PCI-E(x16), Mem 1800MHz GDDR3, GPU 625MHz, 48Pipes, VIVO £151.29 £177.77
Arctic Cooling Freezer 7 Pro - P4 up to 4.4GHz - S775 Dual Core / Core2Duo Ready £14.49 £17.03
Many thanks!
cu3ed said:
Same, except for the ram, working well for me :)
You planning to overclock the lot?
Oh yes ;) As much as possible. Paying £110 for £600 performance appeals to me :D What RAM have you got? RAM is just too expensive at the moment so was planning to get one stick of 1Gb then add another 1Gb after Christmas.
I ended going for the GeiL 6400.
Though part of that was due to previous use of GeiL.
Yea, RAM is pretty high at the mo. I managed to definetly sell my older ram Mobo when the new stuff came so that give me a few more quid to play about with.
Oh i went with the Ninja HS. But it was that or the Arctic.
