Quick Check Before Ordering
4 Apr 2011
Kent
Hello All,
Need a little help with a spec for a friend. All he needs is a PC for internet browsing and use of Dragon Dictate software. No fancy graphics or anything so on-board should be more than sufficient. The budget is £250 Max, including an OS and delivery.
I had a quick go and came up with this:
Microsoft Windows 7 Bundle - Home Premium 64 Bit Microsoft Windows 7 Bundle - Home Premium 64 Bit £68.40
(£57.00) £68.40
(£57.00)
Options applied to the above product:
Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache - OEM (WD5000AAKX) £32.99
(£27.49) £32.99
(£27.49)
Asus P5G41T-M LX Intel G41 (Socket 775) DDR3 Motherboard Asus P5G41T-M LX Intel G41 (Socket 775) DDR3 Motherboard £37.98
(£31.65) £37.98
(£31.65)
Intel Celeron Dual Core E3400 "LGA775" 2.60GHz (800FSB) - Retail Intel Celeron Dual Core E3400 "LGA775" 2.60GHz (800FSB) - Retail £29.99
(£24.99) £29.99
(£24.99)
OCUK EZCool NA-705 Case - Black (500w PSU) OCUK EZCool NA-705 Case - Black (500w PSU) £24.98
(£20.82) £24.98
(£20.82)
Corsair Value 2GB (1x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Single Channel Module (VS2GB1333D3) Corsair Value 2GB (1x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Single Channel Module (VS2GB1333D3) £14.99
(£12.49) £14.99
(£12.49)
Samsung SH-D163C/BEBE SATA 16x DVD-ROM (Black) - OEM Samsung SH-D163C/BEBE SATA 16x DVD-ROM (Black) - OEM £13.99
(£11.66) £13.99
(£11.66)
Sub Total : £186.10
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.75
VAT is being charged at 20.00% VAT : £39.57
Total : £237.42
Will this rig fit his needs or are their cheaper options?
i wouldnt trust that PSU as far as i could throw it. sure, it'll work for a bit on something this low end, but when it goes pop it will almost certainly take something out with it. it'll also be very inefficient, meaning a more expensive, more efficient PSU would be cheaper in the long run. unfortunately that'll push you over your budget:
YOUR BASKET
1 x Microsoft Windows 7 Bundle - Home Premium 64 Bit £68.40
1 x Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache - OEM (WD5000AAKX) £32.99
1 x Corsair Builder Series CX 430W V2 '80 Plus' Power Supply (CMPSU-430CXUKV2) £37.99
1 x Asus P5G41T-M LX Intel G41 (Socket 775) DDR3 Motherboard £37.98
1 x Intel Celeron Dual Core E3400 "LGA775" 2.60GHz (800FSB) - Retail £29.99
1 x OcUK Flamingo FM-12A Midi Tower Case - Black/Blue £21.98
1 x OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £16.99
1 x Corsair Value 2GB (1x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Single Channel Module (VS2GB1333D3) £14.99
Total : £276.31 (includes shipping : £12.50).
*edit*
if your willing to go for some of the B grade stuff, you can get a motherboard thats AM3+ compatible (with a bios update). that means it could be upgraded to an AMD bulldozer chip when they're released (rather than being stuck on a socket that intel left behind ages ago)
YOUR BASKET
1 x AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3) - Retail £41.99
1 x **B Grade** Gigabyte GA-M68MT-S2 (AM3) Motherboard £26.36
Total : £276.70 (includes shipping : £12.50).
