21 Apr 2007 at 14:07 #1 suarve suarve Soldato Joined 8 Oct 2005 Posts 4,184 Location Midlands, UK Just discovered my k800i has a radio Can I just double check that is free, or does it depend on the operator? Ta
21 Apr 2007 at 14:14 #2 GeForce GeForce Soldato Joined 14 Feb 2006 Posts 4,644 Location Surrey, UK It's free. The phone has a tuner inside it
21 Apr 2007 at 14:18 #3 suarve suarve Soldato OP Joined 8 Oct 2005 Posts 4,184 Location Midlands, UK ta just needed tom check, as was using it for a good hour last night.
21 Apr 2007 at 15:05 #4 semi-pro waster semi-pro waster Man of Honour Joined 27 Sep 2004 Posts 25,821 Location Glasgow It is free and slightly annoyingly even if you want to play via the speakers you need the headphones/handsfree connected as it acts as the aeriel.
21 Apr 2007 at 16:12 #5 dsb dsb Associate Joined 31 Jul 2006 Posts 1,409 semi-pro waster said: It is free and slightly annoyingly even if you want to play via the speakers you need the headphones/handsfree connected as it acts as the aeriel. Click to expand... this annoys me as well, what would be good is a sleep timer on there.
