Quick check: pumps + pump controller
You could easily blow your pumps with that controller, that controller is designed for d5 strongs not ddc.
You can run a ddc off a decent lamptron fan controller if you really want to control them and I believe koolance do a ddc pump controller too.
I'll look at that option then, cheers!
The Lamptron FC2 works fine with the 18w DDC pumps tho if u are using the rpm reading lead on ur motherboard cpu header and u are not running the pump at full chat it will give random readings as it will with pretty much any controller that pulses the voltage to adjust the speed.
I was actually considering having 2 of thoes pumps on a single channel but was talked into sticking with a single pump and it would have been pretty close to the 45w limit on the channel anyway.
