Hi all
Before I hang up my boots with o/clocking my new Pc, can you have a quick glance at my setup and assure me all looks well? Is there any obvious errors, or quick hits I can make in terms of an extra slight boost, as I want to crack on with some gaming, feel like I have been tweeking and reading up all week, it's soo addictive....cheers
CPU
External Clock = 360Mhz = 3240Mhz @ 27c
Multiplyer Factor = x9
N/B Strap CPU = By CPU
DRAM Spec = By SPD (4:5) = 450mhz Total = 900mhz
Voltage
CPU = 1.4
DDR2 SDRAM = 2.1
MCH & PCIE = 1.6
RAM
DRAM Timing By SPD
CAS Latency 4
RAS to CAS 4
RAS Precharge 4
Precharge Delay 12
Other Settings
Quick Power On Self Test = Enabled
Thermal Management = Thermal Monitor 2
Limit CPUID = Disabled
C1E Function = Disabled
Executive Disable Bit = Enabled
Virtualization Technology = Disabled
EIST Function = Disabled
Disable Unused PCI Clock = Yes
PEG Force x1 = Disabled
Init Display First = PCI Slot
Bios Version 6.00 PG 15/09/06
Graphics Driver Version = 160.03
GTX 8800 Clock = 630 / 1000
Date Test Run = 12/05/2007
3D Mark 06 Result = 11089
If there is any other settings your interested in that I may have left out to check please ask, as there are so many new bios phrases since I last done this i'm a bit lost with what else you might need to know before signing the above of as complete (for now).
Thanks in advance
Derek
CPU
Voltage
CPU = 1.4
DDR2 SDRAM = 2.1
MCH & PCIE = 1.6
RAM
DRAM Timing By SPD
CAS Latency 4
RAS to CAS 4
RAS Precharge 4
Precharge Delay 12
Other Settings
Thanks in advance
Derek
