Quick cleaning essentials
30 May 2004
Northamptonshire
Hi guys,
I'm off on a two week training course and was wondering what you would take for some quick car cleaning while I'm away?
So far I have bird muck wipes - what else would you take?
Cheers!
I'd take nothing bar what I usually have in the car. I.e a microfibre cloth or two, Auto Glym Fast Glass, and some bug/tar remover.
Snowfoam lance + pressure washer, two buckets, Zymol Royal wax, paint thickness measuring device, rotary buffer with special "waffle" pads, cutting compound, huge pile of microfibre cloths, special light to show up holograms and swirling, wheel cleaner, toothbrush/paintbrush for getting the dust out of small gaps, upholstry cleaner, vacuum cleaner, expensive SLR Camera and lenses to take pictures of results.
Alternatively, forget about your car and see if you can get a life before you go?
EDIT: Sorry, that wasn't meant to be rude, but seriously your car will manage for two weeks...
