Quick coil ?
31 Oct 2007
Gods County(Allegedly)
Have just completed the build of my first cpu & gpu loop. Am giving it a 6/8hrs leak run at the moment so fingers crossed :)
When I bought the ingredients I assumed that I would need :-
Distilled water
Colour of choice
and a Silver coil
I bought :
Mayhems Ultra Pure H20
Mayhems X1 - UV Blue Concentrate
Mayhems Silver coil
Mixed and filled (very pretty blue :D)
Was intending to add the coil but was not sure if I need it (given the Mayhems fluids) or if appropriate ....
I have a Xspc Raystowm cpu block (metal - copper) and an Aqua Computer Gpu block (metals - copper with a stainless steel top.)
Question - should I use the Silver coil and /or should I add some biocide?
Thoughts appreciated :)
I'd add some biocide.
From what I've read from another poster here the silver coils work by corroding into the water preventing bacterial growth. Now the uv blue has anti-corrosion built into it, so the silver coil probably wont be as effective as biocide.
Edit: Just read x1 has biocide in it. No need to add either.
2nd edit: been beaten to it by andybird123. Sorry.
Sell it on the mm perhaps?
Probably cost to post it what it cost to buy :p
Ah well - will probably hang it from the base of my monitor although better half did think that it might make a nice ring (just a bit worried as to the precedent being set :eek:)
Aww go on - you know you want to :D
