Quick compatibility check on case/psu please
20 Oct 2002
London
Following on from my other thread I think I need to get a new case. I like the look of the Thermaltake Versa H15 but it's been ages since I've done a build and I'm unclear what I need to check with regards to compatibility.
My system as it is, is below and I'll be buying a Geforce 1650 Super of some flavour (probably MSI Aero) which is what's forcing me to buy a new case!
I guess the biggy is PSU and mobo. Will the below fit in aforementioned case? Thanks so much.
EDIT: I also have a slimline BD drive, will the case come with a faceplate adapter? :confused:
Everything will fit and that case and it takes a full length gpu so no problem for the 1650.
Case Psu atx but no mention on max length.
No idea about the adapter for the drive.
