8 Mar 2011 at 11:25 #1 julianhj julianhj Associate Joined 27 Aug 2004 Posts 1,083 Location UK Is the logo on the front of this case removable, or is it part of the front grill? I'm after a plain-fronted case and hate big logos!# Edit: to clarify I'm looking at the CM-690 II Advanced Dominator
8 Mar 2011 at 11:46 #2 John24 John24 Associate Joined 25 Oct 2007 Posts 1,500 Yes it is removeable, just tried taking mine off It's just a stick on badge but it's countersunk into the grill and leaves a bit of residue, can probably clean that off though.
8 Mar 2011 at 19:11 #3 julianhj julianhj Associate OP Joined 27 Aug 2004 Posts 1,083 Location UK Thanks, that's really helpful. Countersunk is not perfect, but better than a permanent logo. I'll add it to the spec list.
8 Mar 2011 at 21:31 #4 John24 John24 Associate Joined 25 Oct 2007 Posts 1,500 No problem, thanks for the idea. It's right infront of the fan blades so I'm going to leave mine off too. Good luck with the build.
