quick corsair h55 question
31 Dec 2008
hi, cant find the answer to this, im installing the h55 and i take it i need to plugthe pump into the cpu fan header but my cpu header is 4 pin and the pump is 3 pin does it matter which of the 4 pins i use, like toward the left or right, which pin do i leave free? thanks
It will naturally fit at one end as the 3 pin plug has arms which hug the header slot correctly
Please excuse the technical explanation ;)
ah i see cheers, thought as much figured it out, didnt think it would be that easy to blow something up these days but you never know, temps a lot better with this h55, my artic freezer 7 seemed to not be seated properly for ages and my cpu was reaching like 95% in dragon age! oops, now its like 50 degrees!
