Right I'll go for the cheaper board then. Do you find 16Gb of ram good, or should I just get the cheap 8Gb?
. Really annoying as I was planning on sticking with the Q9550 for another year, however I wanted a RAM boost up from 4GB which wouldn't fit with the massive scyth hsf I have.What sort of a budget have you got in mind for a cooler?Okay 8Gb it is.
Any nice and quiet cooler you'd recommend id I want to play with overclocking?
Well ideally about £30 could go a bit higher but would like to avoid spending £50 if possible. I do like my PC to be very quiet though, I'd sacriface overclock for quietness.
