Quick CPU oc stability test on dual core.
16 Nov 2005
West Midlands, UK.
With my old Opteron 144 I would run Super Pi as a quick test to see if the CPU overclock was stable enough to at least survive a 1MB run. I would then run the longer tests(Prime, Occt etc)to prove it was stable.
With my new CPU(as per sig)I'm getting error messages if I try to run 2 instances of Super Pi, so I wandered what do you use as a quick CPU stability test with a 2 core processor before running the longer tests?
Cheers, dagwoood.
The Asgard said:
2 copies of prime in there own dirs and setting affinity to each core
Thanks for that The Asgard, but I was looking for a quick test and I normally run prime for at least 8 hours when checking for stability.
How do you set the affinity? I came across how to do it some time ago but it's slipped my mind how you do it :o
Edit: Google was my friend and it jogged my memory on how to set the affintiy :)
welshtom said:
the two super pi's must also be in seperate directories, ie you can run the same exe twice.
S"n"M is a good test
That's where I was going wrong then; I created short-cuts from the same directory.
Will S"n"M automatically run both cores or is that a case of a separate directory as well?
welshtom said:
snm will do both automatically.
Thanks for clarifying that :)
I had a thought; as 3Dmark06 is optimized for dual core CPU's, then a run of that would provide a quick way of provisionally seeing if the CPU oc was stable wouldn't it?
