- 10 Apr 2014
- Hampshire
Someone on the forum must know what this is , is it worth using?
your sig link is broken so i cant see what you have but it looks ok, its just a ballpark non ideal setup that will get you something. wont be optimised though. make sure its referring to your cpu of course
Try it run the overclock at 44x say 1.275 voltage and if its stable then reduce voltage till unstables and then add till solid. Add more voltage if unstable at starting point till stable.
I'm sorry but I don't trust people who take a crooked non-full-frame cell phone picture of their monitor instead of using the screen-shot function
Also monitor cpu temps anything above 80c is to much imo, real temp is a good program.
https://www.techpowerup.com/realtemp/
