Quick CPU question!
Don
23 Oct 2005
North Yorkshire
Hi guys,
Intel® Core™ i7-720QM Processor, 1.6GHz with turbo up to 2.8GHz
Is the Turbo mode something that can be "switched" on or is this an automatic thing that processor automatically reverts too?
Thanks
in single thread apps it can run at 2.8ghz...when using four cores it runs at 1.6ghz
im not sure about all laptops but my m17x r2 you can disable it in the bios.....not sure
why you would want to though as its a great feature.....it automatically changes
between the speeds when enabled depending on work load
