Quick cpu temp question
That temperature is just fine. I have an XP 2500 Barton at 50C at the moment.
XP processors are fine at much higher temps than that. I had one a while ago that must have been idling at about 70C for ages (I found randomly one day that the fan had all but stopped working). I didn't monitor it really and had no cause to think that it was getting hot - everything was working perfectly normally. I only realised when cleaning the case out.
So basically, any instability won't be because of this. Have a look in other areas.
