Quick credit card question
Caporegime
30 Jul 2013
Firstly - I pay the full balance of my credit cards every month, I mainly use them for more secure purchases or favoured exchange rates (Halifax clarify) etc.
I made a purchase for £1400 on December 18th and my statement date was 26th Dec.
On December 27th the company credited back £1400 and then re-charged me £1400.
Does this mean they effectively paid off my previous month and I now have an extra month to pay?
Cheers.
In theory yes, but if the credit and debit was done on the same day i would double check with your CC company to be absolutely sure.
The credit and debit may be tagged/referenced by the CC as the same original charge - meaning it may still be recognised as the original balance.
If you get charged i suspect you would get your charges back if you raised the issue as it's clearly ambiguous and confusing for the consumer. But easier to double check - if you're not kept on hold for 3 hrs... :/
**** it, i'll just pay it.
This has become my ethos too.
Life is too short for having your eardrums subjected to classic tunes, crucified and then distorted down a phone line, while on hold, in the hope that you get connected to the right numpty first time around. And that's assuming they don't cut you off with their call transfer skills... :/
Why not wait until your statement comes out and tells you how much you owe that month. Alternatively set your card up as direct debit and let the card company decide if you need to pay it this month or next.
With some cards there is a well known trick to get 0% spending forever. It never used to work with Halifax though.
You'd order something say £500 worth of goods. Get your statement, then order something else for the same price that is returnable without fees. Return that item and you get £500 in your account. The initial £500 spending is paid off by the refunded £500, and the new £500 worth of spending is charged to next month's statement, meaning you've effectively spent at 0%. This would work in perpetuity. (source - http://moneysavinganswers.com/credit-cards/zero-percent-spending-forever/)
It's a bit of robbing Muhammed to pay Abraham, and is faff for both you and the retailers, but it used to work on Barclaycard, Nationwide and a few others.
