Quick crossfire question
6 Sep 2005
Lincs UK
I'm going to be upgrading shortly to an Asus A8N-E nForce4 Ultra (Socket 939) PCI-Express Motherboard (MB-088-AS) and i would like a Connect3D ATI Radeon X1900 XT-X 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (3055) (GX-046-CO) to go with it but do i have to get a master or slave one :confused: or maybe it doesn't matter. I'm only going to be running the one card only.
Thanks in advance :)
you only need the Master card if your going to run 2 cards , you can use the xtx seprate as a main card :)
gr1mey said:
that motherboard doesnt even support crossfire.
Expensive mistake if he bought two X1900's! :eek:
If you want to go Crossfire you'll need a ATI 480 or 580 based motherboard (see sig) Also Abit and DFI versions
the OP states he is using only one card, but if he's using only one card on a board that doesnt even support crossfire then why is he asking about crossfire? :confused:
No idea. Crossfire and SLI are dual cards and require their respective ATI and Nvidia Nforce chipsets. Probably getting confused, or thinks can use SLI on ATI, or Crossfire on Nvidia. :)
