Quick differntial equation question
7 Jan 2003
Gold Coast, Australia
d θ
--- = -K (θ-20)
d t
Determine whether or not the differential equations may be solved by using any one or all of the following methods;
a)Direct Integration
b)Separating the variables
c)Integrating factor
Just to double check myself, which of these will work with the equation?
(a) To solve an equation by direct integration you have to be able to integrate every term. You can integrate the left-hand side, and you can integrate the constant on the right-hand side, but what about the other term.
(b) Edit: Apparently 'separate variables' has a different meaning at A Level than the one I know! In this case you should be able to do it without too much trouble.
(c) Should work - can you see how?
Yeah, assuming K is not a function of theta or t and 20 is a constant, you can separate the variables in order to solve the differential.
