Quick disconnects for graphics card blocks, which ones?
10 Jun 2006
W. Yorks
I decided the next time I stripped out my watercooling to fit new parts or just give it a clean I would fit quick disconnects.
I have looked at the Koolance ones on OcUK but there are so many. My plan is to fit them to the graphics block I have just ordered (Aqua Computer Kryographics for R9 290/290X) so I can take the cards out of the loop a lot easier instead of draining the whole system.
I am using the XSPC Highflex hose 7/16" ID and 5/8" OD and the Bitspower Compression Fitting (7/16" to 5/8") - Black Sparkle.
Could someone point me in the right direction please?
Find a pair from the same series and have the female end with a G1/4 thread to screw into the gpu block (or angled fitting) and the male end with a 1/2" barb for the tubing.
No hijacking here but does anyone know how long the QDC's are? I'm asking cos im also thinking about installing these but worried about the space they take up.
It depends on which particular series/model tbh. I believe the QD3/QD4 series are shorter than the older models.
You could always use a tube to tube QDC rather than a straight to component fitting if space is a concern.
