- 29 Aug 2010
- Cornwall
Hi,
(Another) Quick question...
Is it ok to use Quick disconnect fitting in water-cooling loops or are they too restrictive? How many can you use before they make the loop too restrictive?
What about right angle connectors? The ones I have seem to be quite narrow.
If it makes any difference the rest of the kit I'm using is:
Swiftech MCP35X pump
HeatKiller 3.0 CU CPU block
EK 5870 Copper + Plexi GPU block
240mm EK Coolstream Rad
XSPC RS240 Rad
Thanks.
XSPC RS240 Rad
Thanks.
