quick ds3 help needed
18 Oct 2002
Isle of man
Hi there
2 questions brand new build tonight but am astuck....
1. cant get in to the raid screen to set my drives up raid is enabled in bios and it says wait until you see the messge press ctrl+g for raid setups creen on post it dont happen
2. I cant seem to get the advancd menu by pressing ctrl=F1 what extra menus am i meant to see?
2x 74 gb raptors plugged int the first orange sata controller doe sit matter which ones its plugged in to?
flashed latest f7 bios
cpu is e6400 week 28b with cucial 10th anny
i cant install untill this is sorted thanks in advance!
You press CTRL+F1 on the main BIOS screen (screen will flash to indicate) then when you go into the M.I.T the memory timings will be opened up, only one i can help with. :)
ok thanks loadsamoney i just sorted the raid...it had to be in the other SATA port (purple one) to enable the raid bios, manual dident mention it at all
yeh i can see my memory timeings under mit thats it then? do u have to press f1+ctrl ever time? u enter bios?
