Just installed the Noctua NH-U12F and i noticed temps hadnt seem to of dropped from stock cooler (maybe i need to give more burn in time). I then played some BF2142, and when i finished i check the temps and it said 51c.... its never gone that high b4, even with the stock cooler. is it safe?
Im using Asus Probe that came with my mobo, and my cpu is overclocked to 3ghz. I have only raised the FSB and left all voltages at standard. Will just raising FSB still raise the temps that much?
Gonna try reapplying and reseating the heat sink, and ill follow the guide on applying TIM off the arctic silver site.
Thanks folks.
Thanks folks.
