Quick easy AOL question
Caporegime
8 Jul 2003
In a house
Right, im doing a re-install of windows for my dad and just want to know, seen as ive got the modem drivers downloaded off their site, can i just install those, then bang the AOL 9 CD in to install the sofware (as he had to get them to send an AOL 9 CD out seen as he couldn't find his), or does the CD also contain the modem drivers as well as the software, so i can just pop that in the drive, and that will install the modem first, then do the software.
Thanks. :)
yes i use AOL, with the disk i got, you just run the cd and it installs the drivers and software, just dont plug the modem in till the installation prog tells you to :)
