i have 2x512mb of geil duel channel ultra pc3200 golden dragon 400mhz ddr and i need another 1 gig.
Memory of the same spec(like below) will work ok alongside it wont it? and will i lose dual channel if i add more than 2 sticks to my motherboard which has 4 slots.
just checking before i place an order, dont want to order the wrong thing ....again
THinking on getting this:
GeIL 1GB (2x512MB) PC3200 Ultra-X nForce4 Special Edition CAS2 (GLXNF1GB3200DC) (MY-056-GL)
The new DDR UltraX nForce4 Edition is now being added to GeIL’s DDR performance memory module lineup. This particular UltraX model is specially designed for nForce4 platform motherboards with the ultra low latency of 2-2-2-5 1T command. *Note: Event though this model of DDR UltraX is named nForce4 Edition, but it will still work on most Intel based motherboards with CAS clocking at 2-3-3-6.
- 184pin, Non-ECC, Un-buffered, high performance DDR memory modules
- Hand Picked GeIL Ultra-X TSOP 32x8 DDR Chips
- 6 Layers Ultra Low Noises Shielded PCB with Gold 30u" Plating
- Optimized SPD for Dual Channel DDR motherboards
- Coated Platinum Copper Heat Spreader
- CAS 2-5-2-2-1T @ DDR400 PC3200
- 2.55V-2.85V
- Retail package with blue acrylic case and instructions
- Lifetime return to manufacturer warranty
Price: £79.95 (£93.94 Including VAT at 17.5%)
thanks
- 2.55V-2.85V
thanks
