- 22 Dec 2012
Hey there, I have quite an old mobo - (Nvidia EVGA nForce 78i SLI) and I'm seriously considering buying the EVGA GeForce GTX 660Ti as an upgrade. Would anybody be able to tell me if everything would be compatible between the two?
I know the AMD cards are better value, but I might be interested in doing SLI in the future so would like to stick to Nvidia. I'm going to have to find the physical specifications to make sure that it'll actually fit in my case, but my old GPU was a GeForce 8800GTX which was quite a hefty card so I'm sure that it will be fine.
My last question (having never installed a GPU before) is, since my old GPU has essentially died (artifacts on screen, wont boot windows) if I remove it and plug in this new one, will I have difficulties.. as wont it be trying to run from my 8800GTX drivers?? I'm rubbish at this stuff, thanks for the help!
